I want to remove the remaining gas from the fuel tank because I think it's stale
There's not much left in there as far as I can tell but I'd like to remove as much of what is left as possible so I can put fresh gas in without the old stuff mixing with it
What's the best way to go about doing that?
Siphoning? I have a little Wally World hand siphon that works pretty well but keeping the hose in the right spot may prove difficult
Would disconnecting the fuel line and using the primer bulb to pump it out be a better option? Or an option at all?
Removing the tank itself is not an option in this case as that would be a whole lot of effort not worth the trouble
The other option I was thinking was just to add several gallons of fresh gas which would dilute the old stale stuff. Problem is I can't really tell how much old is left and I would think that would work only if there's very little old remaining
Anyway, happy to hear suggestions!
Thanks!
Thanks!
