lkmurraylvr
Thread starter- Joined
- Sep 6, 2007
- 7
Hi all,
I've got a bastardized 94 mercury blackmax 150 carbed outboard that's been having some issues. Main problem is it seems a cylinder is sometimes not firing. Sometimes it'll come right up on plane and other times I have to play with it and choke it to get it up. Sometimes my top speed is only 35 or so and then it'll feel like another cylinder kicks in and my speed will pick up by 7-8 mph then the power drops off again. It'll come and go quickly sometimes. The only thing I've found in my limited testing is that the intake manifold gasket is pretty much gone. Large areas are blown out on each side. I know this is causing the spitting and sputtering when I give it gas and on idle, but could it cause my erratic power delivery? And if not, could anyone give me any pointers where else to look? I checked the plugs and they're fine....I'll be checking the ignition in the a.m. Any other pointers would be much appreciated.
Thanks,
Jason
Thanks,
Jason
