Fiat4Fun
Thread starter- Joined
- Sep 14, 2009
- 229
Howdy,
Took the boat out for the fourth time this season, and was having a great day, Running all over the place, full throttle, cruising, slow, everything was fine.
About five hours in, as we were pulling the kids on a four man "couch" for about 20minutes, we heard a bad sound come from the engine, very mechanical, and I cut the throttle, and then turned the engine off. Checked under the "hood" and saw nothing strange, tried to restart, and heard more mechanical noises.
We then tilted the drive up to see if something was noticeable, saw nothing strange. Then restarted, engine started, sounding a bit rough, and tried to put in the gear, and nothing……… no forward , no reverse. Check to make sure the cables were ok, and the "shoe " was moving and all was fine.
So we towed it back to the dock, and that was the end of the day……
So now I need to dig deeper. A bit of history, it is a 1986 Alpha One Gen One, with a 265 HP V8. I had it serviced at the end of last year, my mechanic found metallic dust in the oil, and the lower end was bad, sent it back to Sierra and got a new one under warranty. The upper was checked out by a mercruiser dealer, and it tested fine. We have had it out for a few times this year and no issues. I think the upper went, as it should be the weakest link, but I know the shifting is done in the lower.
I am thinking it is drive issue, as the motor seems strong.
Any advice on what to check before I tear it apart? I am thinking of just yanking the drive of the back of the boat, and seeing if something is obvious…..
Any other advice is greatly appreciated.
Bob
Bob
