clemsonfor
Thread starter- Joined
- Sep 19, 2005
- 1,011
I have a 81' johnson 60hp. Last weekend it was hard to start and when it would catch it would fire one is all then it would run for 2-3 seconds then quit. I fugured i flooded it so after several attempts it started and ran fine for 2-3 hours of stop and go and continuous running, and fine restarts. Never been hard to start before. Then this weekend i start it fine and idle out then fast idle or 1/4 throttle just where you almost throw your largest wake, then throttle down to fast idle speen then open it up and instantly cuts out. I try and restart it wont so i ge t the trolling motor out and head back all while trying to restart. Would not start checked for spark on both plugs, and nothing. So go to the house and after several hours hook to the muffs and it starts fine but will cut out every now and then , which it would not do before, but would always restart and idle. I am thinking bad power pack, do any of yall have any thoughts. If you need more info on specific things ask ill try and fill in parts of diagnostic info if needed!
Oh a past problem was i think the kill wire shorting out as it would cut off then all of a sudden restart, i replaced the wire harness and this went away so i have a new harness and had many hours of trouble free running since this problem.
Now that i am thinking about it sometimes it was hard to restart warm just after switched off but very very infrequently!
Im getting frustrated with this it cust out wont restart then back at the house 3 hours later it starts?
-Nate
-Nate
