Bad Pulse Limiter?
packman35
I am trying to diagnose and fix a lean running 93 115TLET. It is running lean and will not idle.
I pulled the pulse limiter and it was not clogged or anything that I could tell. I squirted carb cleaner through it. I blew air through it and air would flow in both directions.
My manual says that the PL is a check valve. Shouldn't that mean that air only flows one direction? Could free flow in both directions mean a bad PL? Could this cause my fuel pump to not work - causing my lean issue?
Thanks in advance!!
ezeke
Re: Bad Pulse Limiter?
When functioning properly the pulse limiter only closes when the air passing through it moves at abnormally high speed, such as during a backfire. Its function is to protect the fuel pump.
kenmyfam
Agree 100% ^^^^^^^ with the above. ^^^^^^
packman35
Thanks guys!!! I'll check that one off as not being my problem and move on to the next one.
kenmyfam
Did you give the carb's a "proper cleaning out" ???
packman35
Yep, I've cleaned and reassembled the carbs three times. It seems like I have either an air leak somewhere or my VRO pump is malfunctioning.
However, being the idiot that I am, I have now managed to shear off the pulse limiter while trying to reinstall it. Maybe it had a crack and that was where my air leak was. In either case, it looks like I am going to be pulling out the screw extractors to get the piece out of the block.
Oh fun day!!
