clemsonfor
Thread starter- Joined
- Sep 19, 2005
- 1,011
Im 90% sure its dead.
I have a 1990 johnson 150gt. I have had the problem for over a yr now. I just found the pinned thread i think by spinnerbait nut about testing the tach. That tells you to remove the grey wire at the terminal block and hook it to the yellow grey wire at the terminal block going to the stator. If the tach works you have a bad tach if not bad rectifier. I had no tach doing this.
The other reason i think the rectifier is bad is that my charging gauge always just shows 12-13 like the battery volts and the tach wont work. Well it works sometimes or most of the time at startup for a min or 3 max and it charges up to 14 on the gauge, then will drop on the volt meter and tach will quit.
My Real question is do these things just go dead or is it customary for them to do like i have seen and work for a few mins then stop right after startup?
If you dont think its the rectifier positively shoot me another direction.
