patrick4266
Thread starter- Joined
- Nov 29, 2007
- 591
Will a bad retifier stop a motor from starting? 1983 johnson-70-hp
For some reason it quit cranking from the key, will crank if I put a hot wire to the selonoid but still acts like it is not getting fire. Gotrained out so i could not check it farther.
Sounds like an issue in the remote box, disconnect it from the motor- there should be a plug , then try. My rectifier was blown on my 90 and it still started no problem.
That's because the rectifier is for charging the battery----only. It has nothing to do with the ignition system or running.
patrick, re-read my earlier reply, if it is not cranking fast enough you won't have spark. Since yours isn't cranking at all without jumping, that gives credibility to what I said. Don't ignore the obvious.
It is cranking real good
Either way, iboat rules (section 3, article 9, page 49, line 1) say.....ALL IBOAT POSTERS WILL report back to "the community" and post the solution to their problem, so someone else might learn from your mistakes, ignorance and inexperience.Thanks F R I will do that as soon as the weather breaks. I got the manual, set me back 78 dollarsbut I am sure it will pay for it's self. I am going to start reading it and see if I can figure it out, if not I'll be back
LOL, As a lifelong auto tech I can sure relate to that.$78 seems a lot but just read some of the daily posts here.
" I replaced the power pack but it still won't fire, so I replaced the stator and it still won't fire, the manual to too expensive".
Meanwhile after $450 in guessing and throwing parts at it , a manual would have helped find the simple problem.
