Re: bad relays?
hello<br /> if you switched the relay location and the symptom staryed the same its not a relay. thats a quick test good going. now dissconnect the cowl trim switch if used, see if it does it again, if it does disscoonect the 3or5pin trim harness connector to eliminate the console trim and trim harness and see if the symptom goes away. its a quick easy process of elimination then you can further isolate it with a multimeter.<br /> good luck and keep posting
