bad stator=battery charging probs?????
bluebrownie
had stator problem...can a bad stator lead to a poorly charging battery... ?
Barnacle_Bill
Re: bad stator=battery charging probs?????
Yes but the most common problem is dirt or corroded connections. Check them all to be sure they are clean and tight. Next most common is you rectifier/regulator. If you have ever connected the battery up backwards, even for a split second, the rectifier is toast. They can be checked according to your manual.
bluebrownie
i changed the rectifier earlier this year... was having probs with the motor conking out when hot... took cowling off...no problems... and did a few other things... new stator going in next week, but i have noticed that battery is doesnt have alot of juice...have had to leave trickle charger on...i cleaned all terminals and connections...
