I have a 1983 85HP Force that is no longer charging.
Have been doing some troubleshooting and so far this is what I found.
Rectifier tests good. (Replaced last year with one from Radio Shack)
All grounds and connections cleaned and look good.
On to the stator test...and heres where there seems to be an issue.
The manual I have states that to test the stator you measure impedance between the two appropriate wires coming from the Stator.
From the manual it states that it should measure between .5-1.
Mine measures 1.6.
Thoughts on this? Am I due for a replacement stator? Or any other ideas?
Thanks
BTW, the engine starts right up....
Mine measures 1.6.
Thanks
