Bad switch box on 1973 Merc 20hp?
astrodude
Guys, need help here. Motor is 1973 Mercury 20HP. the top cylinder is not firing. switched wires of the two coils and the bottom would not fire. so I believe the coils are OK, the plug wires are OK. Now is it a problem with the switch box or even upward a bad stator or trigger? How do I test it?
From what I understand, if one cyl has spark, the stator should be fine, could be the corresponding trigger or switch not functioning. If this is the case, can I swap the switch box input wires from trigger to check if the trigger is working properly? If the problem still remains should be a bad switch box if problem follows to the other cyl should be a bad trigger?
One more thing to add, the top cyl is not completely dead to me because when the engine is running it fires for a short time and when I do spark test, I did see some sparks one time.
