CaneCutter79
Thread starter- Joined
- May 24, 2009
- 454
I have a 1979 Evinrude 85hp outboard. I bought a used OMC tachometer last year and it's worked fine until my last two outings. The tach needle is reading somewhere around 6,000rpm (stuck) and will not respond to the motor. Usually, when I turn the key on, the needle drops to "0". I have checked the wiring and it's getting both positive and ground connections. I don't recall if I checked the pulse wire but it should be working as well. If not, that would explain it but if the pulse wire is good, is there a chance the tachometer is busted?
I have a 31yr old boat and drilled a hole in the original dash. I hope this tach is not busted and if it is, I can find another one to replace it now that I have a 3" hole cored into the dash.
Thanks!
Thanks!
