Re: Bad timer base? Soldering the wire damage inner sensors?
I am glad you got it running and soldered up and just thought would pass along a method or two that a friend uses in your situation. He has a really deft touch with a soldering gun and usually he can just tin up both wires with solder and then melt the solder together with the wires running parallel for the length of the stripped insulation. Then he covers it with heat shrink. He believes it makes a stronger connection then twisting and then soldering the wires. Another trick he uses with the ininsulated butt connectors is to crimp them to the wires and then heat the connector with a cigarette lighter in the center and hold solder at the crimped ends. When the metal butt connector gets hot it will draw the solder down into the connector. Then he covers it with heat shrink. This works real well when you are away from land or AC power, and holds up well also.
