Bad transom repair?
KewlBird
Well it was finally warm enough to go outside and mess around with my boat...Here's what I found...The transom was replaced at one point in time (check the pictures, all will enlarge if you click on them). Looks like who ever did it cut out all of the fiberglass on the interior of the boat and stuck some new boards in and covered them with a single layer of fiberglass mat. The board in the middle is fairly thick but the ones on the port and starboard sides are much thinner (looks to be thinner than the original was). On the exterior you can see where the transom is cut and some fiberglass was globbed on. There appears to be no adhesion between the exterior fiberglass and the wood (I can peel the fiberlass back). I'm not sure if this is a good fix or a hack job. I don't know a lot about repairing transoms but was planning to replace this with seacast until I saw that there isn't an interior wall. Looks like the top shell of the boat would be possible to remove to gain access to transom. Any suggestions? I planned on putting my 85hp Johnson on this, I'm sure I would need to repair this before attempting to put this motor on it. Here's a bunch of pictures, you can see what was done. Being new to boat repair I am open to any suggestions. I'm not affraid of work but am afraid of loosing my outboard ;).
Click on images to enlarge:
Ride The Lightning
Re: Bad transom repair?
Hi,
that looks just horrible.
I would not even try to drive this boat with 85HP. Do you know how the wood was bonded in? The mats beyond are likely to have no effect.
Regards,
Lars
drewmitch44
Yea and you are going to have to eather cut the splashwell off or seperate the top. Or you can do like i did and cut the top like 1 or 3 feet from the back of the boat and just take the top off of the back of the boat. Thats what i did. Ill try to see if i have any pictures. That way seemed easy to me and now got good acess to the transom without everything in the way. If i dont have pics i will go and take some in a few min and post them in an hour or 2. That is actually the point where im at.
KewlBird
Hi,
Regards,
Lars
The only thing that appears to be holding the wood is the mats they applied which is fiberglass to the floor :confused:. I don't think there is any bond betweed the wood and the exterior layer of the boat.
Thanks drewmitch44, I'll look forward to some pictures :)
beauff
Wow someone did a nice job on that.I wish you luck. That would be a big job for me .
Coors
Sorry, but that is one hell of a hack job.
drewmitch44
my wife is calling me to bed but i gotta show ya a couple pics! ill talk more tomorrow morning!
drewmitch44
ok Im back with pics. They were too big so i had to upload them to photobucket. Well here they are and i am going to try to post a link to the album in photobucket also so you can look through there too. I think it is going to be a lot easier to do the transom now without the splashwell and all that in the way. Now i have a unobstructed access to the transom without anything in the way so it should be pretty easy. Ok Since they now allow links i just went ahead and linked a bunch of pics. I put a lot of em in there cause i dont know if it will help ya or not but here are the pics. Let me know what ya think. Sorry there are so manny but i dont know how to get photobucket to put them in order so i linked them here so that they are in order some what. I think that the previous owner of the boat put that Steel plate on the transom so that they could get by without replacing the transom. I am going to do it right but i like that plate, and its stainless so i think im going to put it back on when im done replacing the transom. They did not put anything in the holes for the splashwell drains so anytime water came into the splashwell it touched the wood of the transom making it rot even worse than it was. Thats ok though cause i got everything apart now and will be doing it right. I hope these pictures help you.
here are the links:
http://i187.photobucket.com/albums/x43/drewmitch44/motoroff2.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Motoroff-1.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Motoroff3.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Motoroff4.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Motoroff5.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Motoroff6.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Motoroff7.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Topview.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Plate.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Plateoff.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/plateoff2.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/plateoff3.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/plate2.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/plate3.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/splashwell.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/splashwell2.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/topless.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Topless2.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/topless3.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/splashwell3.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/topoff.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/splashwelloff.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/Rotted.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/rotted2.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/rotted3.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/rotted4.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/rotted5.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/rotted6.jpg
http://i187.photobucket.com/albums/x43/drewmitch44/rotted7.jpg
KewlBird
Thanks drewmitch44 for all the pictures, gives me an idea of what I might see when I pull the shell. Having that off of there deffinately gives a LOT more room to work with. Couple of questions for you: 1. How do you plan on reattaching the splash shield where you cut it (fiberglass it back together?)? 2. Are you replacing the transom with new wood or doing the pourable stuff?
Thanks again, gives me hope...I might start disassembly today, weather seems ok.
BTW, I might be pulling the floor and replacing it as well mainly because there is a spot where "they" also repaired the hull and I want to see it from the inside. So removing the whole shell would be a good idea.
Ride The Lightning
Hi,
I think you are on the right way. You have to remove the old stuff completely and build a new transom.
Take pictures of your work and show them, so we can help much better.
Regards
Lars
oops!
hey drew...??? can ya help the guy...???? :D:D:D lol (good job)
yup....the transom has to come out......however ugly it looks.....it can be fixed.......
its just a transom replacement.......
were here with help
cheers
oops
jasono2l
Man that is truly a hack job, I hope that if I need to replace my transom I can do a better job than that guy did on your boat. Good luck with that man.
KewlBird
Can someone tell me if something is missing in the bilge, are there supposed to be some sort of runners under that floor? Those are views from underneath the floor. Last pictures shows some sort of a wood block that lifts the floor up in the back, I'm not sure why :confused:. I haven't done anything on it yet. I'm being told by my family to drop this project and buy my self a better boat. I have to think about this one, the cost to repair so far is around $800 for the supplies, then I have to paint it too......
TriadSteeler
KewlBird,
I think your family is giving you some sage advice here. I always love a challenge, my current project is evidence of that. I would never want to dissuade anyone from rolling up their sleeves and bringing an old girl back to life. However, after looking at the transom job and the stringer/floor modifications that were made, I would haul that thing to the dump.
Normal rot from exposure and people who get excited drilling holes in the transom are one thing. This is something entirely different. Based on the craftsmanship displayed in those pictures there's no telling what other surprises await. Some you may not even discover until after your money has been spent.
In addition, the person making those repairs was more than likely the same person operating it as well. And to me that is a scary thought indeed.
Coors
If you want to do it, go.
When finished, you can sit back, and be proud. And know the boat is safe.
Besides, it will keep you off the streets.
Solittle
Those runners are called stringers and are part of the boat's structure.
If you have already spent $800.00 my guess is that you have $800-1,000.00 to go. Your call on whether to continue.
erikgreen
Just from what I can see in those pics, the floor, stringers, and transom were done by someone who didn't know how, and didn't have the address of this bulletin board to get help :)
Odds are pretty good they all need replacement. That's a $1000 or more job, just counting materials and your time. Lots of people here have done it, and if you like working with your hands it's very fulfilling. Plus you end up with a boat that's better built than when it came from the factory. You won't even break even on the repairs, though - do it if you like the boat and want to keep it for a few years.
On the other hand if you're hoping to get on the water before fall, another boat would be a good idea.
Erik
drewmitch44
Im doing my transom tomorrw and i want to be on the water by late fall or early summer! I got stringers to do yet and a bunch of other stuff! Im going to do that as i go.
KewlBird
Well, here's the latest news. I gave up on this thing and will attempt to sell it. It will be hard to sell a "project boat", I'm not sure if anyone will even want it. At least I might be able to get some money for the trailer. While this thing is up for sale here's what I acquired. A 1985 16' Aluminum hull Starcraft, with a 70hp Evinrude (ptt) and a trailer for $1,200 :D. Interior needs complete overhaul but I think the boat was worth the amount I spent on it. Here's couple of pictures (no, that's not my boat in the background :( ):
Thanks to everyone who helped!!!:)
