Oillywater
Thread starter- Joined
- Jun 10, 2023
- 96
Hello I have a 1988 force 125 motor and I’ve been having problems getting it to run good timing was way out of time got it set to 28 and cleaned the carbs in some chem dip came out shining. Boat ran better but still not good and would pop and backfire and die.
Then took it out to water to test it ran for about enough time to get me out of the dock then died and wouldn’t turn back on out of desperation I messed with the timing got it to turn on limped back home. Set it aside.
Currently I’ve cleaned the carbs again just in case new needles. bowl gasket and mount gasket new port gaskets. When to start the boat and it didn’t like to start but it would and just stall after like 40 second then once it warms up it stays on for a while but will stall eventually. I remember I messed with the timing so set up my gun to it and noticed it was at tdc at full throttle. Then moved the screw nothing. Even moved it all the way out and all the way in. It stayed at tdc. Could it be a bad trigger
Please help and thanks for your time. I just wanna go fishing?
