USA_boater
Thread starter- Joined
- Jul 31, 2018
- 277
2004 Four Winns H180 w/ VP 4.3GL...trim motor was intermittently working last year when you hit the switch on the throttle stick. This year, noting but relays click noise when you hit the switch. Soooo I tired to do my own redneck trouble shooting and may have made it worse.
- first tried swapping the relays with some "like" relays of an '04 Jeep that fit the plugs. They too clicked so I assumed that meant the motor itself was the culprit.
- then tried beating on trim motor housing with mallet, then hammer when mallet didn't work. Figured it was like an automotive starter when it has a dead spot on the brushes. But ultimately I probably did more damage because when I took out the old motor the magnets were in pieces and motor couldn't turn at all.
- took old motor off an ordered a new one that I have not received yet. But now after having the wife fit the trim switch on the throttle so many times while I was doing the trouble shooting, neither set of relays I have click anymore and the fuse is good!
I went ahead and ordered 2 new proper relays but haven't tried them yet. But SHOULD THE RELAYS CLICK IF INSTALLED WITHOUT THE MOTOR BEING INSTALLED TOO?
I figure I either have a bad trim switch now at the throttle stick, OR I burned up some wires or something?
The plan is to hookup the new motor and old relays first, then try the new relays and if neither of those work, then I need advice on what else it could be besides the trim switch itself which would be my fault and a new issue! Thanks guys!
PS, how can I see a list of my past threads if I didn't subscribe to them? I think I had a thread from last year on the trim when it first acted up but I couldn't locate it.
