speterson1011
Thread starter- Joined
- Aug 30, 2010
- 65
Ok so I will get to the point. I changed out my impeller. It was the correct replacement for sure and all of the o rings were put back in. The impeller was turned the right way so it is flowing water in the right direction inside the water pump housing. I turned the engine over and it would not pee what it normally did. So I took off the piece where the water stream comes out of so if anything was clogged it would come out since more water can flow out of it. Nothing came out, I also tried poking way down in there just in case it was clogged but still nothing. Put the piece back on and it still peed the same. It's a weak flow, it only shoots a few inches away from the engine. I used the impeller lube when I put it back together as well. I tested this on ear muffs and out on the water. While I was coming in it did throw a hot light. It has the right amount of oil and I put new thermostats and thermostat springs in also. Still the same thing. Does anyone have anymore ideas? I was thinking maybe some of the gaskets and the large o ring on the water pump are bad and it is leaking some down there? Also I was sure to put the impeller key back in. I also took apart the inlet where it intakes water at the bottom of the foot but still nothing. It is a 2000 90HP 2 STROKE 4 CYL. Thanks
