I am rebuilding my engine, the previous block was a 4 bolt main. My new block is a 2 bolt main. not a problem at all so far. My question is; the old block (4bolt main) had studs attached to the middle bolts to hold the baffle assembly in the oil pan. Is it ok for me to take the studs/bolts off of the old block and replace the studs/bolts on the new block (2 bolt main) or is the baffle assembly even needed. I have been told that I do not have to worry about it. I have also been told that you dont want to change those bolts. Anyone with knowledge of this please help. I hope that I gave enough info for this particular situation.
1988 Gen IV 454 Hi perf marine engine
