Ball Size ??
dodger7847
I have a 12ft alum boat which i pull with my ford explorer with 1//7/8 ball now i have a 18ft glastron trihull,trailer has 2" ball would it be ok to change to a 1/7/8 ball or is the boat too heavy, seems very little difference between the 2 ball sizes any help ??thanks.
bonz_d
Re: Ball Size ??
You could possibly get away this a 1 7/8 coupler as many years ago that was a normal commonly used size. If you have a receiver hitch it would be better to just get a another drawbar and ball.
colbyt
Re: Ball Size ??
Buy a 2" ball and a 2" coupler to fit your 12 foot boat trailer. With smart shopping you are talking less than $25. Buying another draw bar will cost more than that. Though if the 1-78 is welded on that may be your only choice.
Bullelk34
Re: Ball Size ??
Ditch the 1 7/8, get a new tongue welded on for your 12' in 2". Piece of cake to do it yourself or have it done.
bonz_d
Re: Ball Size ??
You guys are thinking much more clearly than I am this morning. Must be getting tired from working all night.
Agreed that switching all to the 2" ball makes the best sense.
NYBo
Re: Ball Size ??
A 1 7/8" ball has a maximum capacity of 2000. This is based on the size and strength of the shank, not the ball itself. Your larger boat is likely over that limit.
UncleWillie
Re: Ball Size ??
The 1-7/8 Ball has a 2000# limit.
The 2" Ball has towing limits that vary from 3500# to 8000# depending on the Ball.
The Ball Shank comes in 3/4"and 1" Diameter.
Do not put a 3/4" Shank Ball in a Ball Mount with a 1" hole!
The Hitch, Ball Mount, and Ball all have there own ratings.
The lowest of the set is your tow rating.
A 6000# Ball mount with a 3500# Ball, and a 5000# Hitch means 3500# Max.
It's the weakest link in the chain theory.
Go read the numbers off of your parts.
82rude
Re: Ball Size ??
ive had for the last 7 years or so an interchangeable ball system that comes with 1 7/8 , 2, and 2 5/16ths balls that go on to the same shank .works great ,towed lots in all conditions ,never an issue.to change you just turn the slot on the top with a quarter or slotted screwdriver ,slip off the current ball and put on the required size and lock in place.ive been down some pretty rough roads up here and never a problem.
dodger7847
Re: Ball Size ??
Thanks for all your help guys, I think ill just put a 2" on the small trailer thats the 12ft alum boat, again thanks.
JimS123
Re: Ball Size ??
If you look at those little dinky jetski trailers you'll find that most come with a 2" ball. That's because most jetskiers have a big boat as well. All my trailers were converted to 2" many years ago, just to standardize.
H20Rat
NYBo
Re: Ball Size ??
I've never seen one with a 1" shank. You keep teaching me stuff today!:redface:
Now, how about a coupler to match?
EDIT: Other than multifits!:apologetic:
MH Hawker
Re: Ball Size ??
Take a close look at the 1 7/8 hitch its self, some can be adjusted to take a 2 inch ball.
bassman284
Re: Ball Size ??
Got one on a shelf in my garage. Sell it to you cheap. Used very gently.
spdracr39
Re: Ball Size ??
Put a 2 5/8 ball on everything that way no one can borrow your boat :D
