Barbed hose connectors - how snug should they fit?
hempfarmer
Hi all,
I am adding a in-boat fuel filter to a 3/8 fuel line. I am little unsure whether I have the right size barbed brass hose connectors....When I connect the 3/8 line the barb connector slides right in. Should it be a tight squeeze to get these barbed connectors in the hose?
I figured what is the point of having a 3/8 line if these brass connectors on the fuel filter end up restricting the flow. Just wondering if these brass connectors I had on another boat are the wrong size.
Thank you!
Russ
boobie
Re: Barbed hose connectors - how snug should they fit?
See if you can get some 3/8 " barbed connectors for the filter. On a lot of filters you can change the connectors.
hempfarmer
anyone know if using 5/16 connectors with a 3/8 line would be detrimental to performance on a 115HP ETEC?
hempfarmer
Can you buy these brass connectors at any hardware store?
Will Bark
If you have a Lowe's or Home Depot close by they have a great selection of barbed hose connectors. It's best to have the corrwct connector. Good luck
