I heard that today too. It was muriatic acid as the active ingredient. Can anyone verify this?Originally posted by crazy charlie:<br /> Go to Walmart and buy Snobowl toilet bowl cleaner.Only .99 cents.Saturate the barns and let it sit for a bit.A stiff brush should do it but I have been successful with a pressurewasher the same day as it came out of the water.If no luck with that,the buy some Marykate On-Off and that should work.Charlie
It is not muriatic acid for sure.I think it said chloride on the label.Originally posted by magster65:<br />I heard that today too. It was muriatic acid as the active ingredient. Can anyone verify this?Originally posted by crazy charlie:<br /> Go to Walmart and buy Snobowl toilet bowl cleaner.Only .99 cents.Saturate the barns and let it sit for a bit.A stiff brush should do it but I have been successful with a pressurewasher the same day as it came out of the water.If no luck with that,the buy some Marykate On-Off and that should work.Charlie
Originally posted by crazy charlie:<br /><br /><br />It is not muriatic acid for sure.I think it said chloride on the label.Originally posted by magster65:<br />I heard that today too. It was muriatic acid as the active ingredient. Can anyone verify this?Originally posted by crazy charlie:<br /> Go to Walmart and buy Snobowl toilet bowl cleaner.Only .99 cents.Saturate the barns and let it sit for a bit.A stiff brush should do it but I have been successful with a pressurewasher the same day as it came out of the water.If no luck with that,the buy some Marykate On-Off and that should work.Charlie
The leg has the factory merc coating on it... I think it's powdercoating. The props are stainless. Thank you for the warning and I'll keep that in mind.Originally posted by gavin dunne:<br /> As a chemist I'd be very cautious about cleaning aluminium with muriatic acid (I presume it's an aluminium leg and prop). Sure it'll dissolve up the barnacle crud but it will eat into any exposed aluminium very quickly. If you must then, use only a very dilute solution and you sure better wash it off thoroughly. That's a beautiful boat you got so I'd stick with the elbow grease.
