Base timing on TB5 350 V8 Carbureted with knock Sensor???
tank1949
My Selock manual is as useless as tits on a frog. I timed these motors years ago but have forgot which wires to disconnect at distributor. I did some motor work and have to reset timing. I believe I must disconnect knock sensor, but my old memory keeps telling me that I need to disconnect something else. Selock is vague. Selock states that I should have distributor advance set at 8 degrees, but I don't trust that either. Any suggestions???
Scott06
What year or heads do you have prevortec is 8 degreees btdc, vortec 10 degrees btdc
Fun Times
V6 and V8 Carbureted Models (Thunderbolt V Ignition)
1. Connect timing light (91-99379 or similar) to No. 1 spark plug wire. Connect power supply leads, if applicable, on light to 12 volt battery. Refer to Specifications – “Engine Rotation and Firing Order” for cylinder numbering and location.
2. Connect a shop tachometer to engine.
3. Using a jumper wire, connect the ignition system timing lead (PUR/WHT wire) to a good engine ground (-). This locks the ignition module into the “Base Timing Mode”.
NOTE: Before starting engine make sure the timing tab and marks on damper are clean. Chalk or white paint on timing marks may help visibility.
4. Start engine and run at normal idle speed. Allow engine to reach normal operating temperature.
5. Aim timing light at timing tab, located on the timing gear cover and crankshaft torsional damper.
6. If adjustment is required, adjust timing by loosening distributor clamp and rotating distributor body as required until timing mark on damper or pulley lines up with the mark on tab specified in “Specifications”. Tighten clamp and recheck location of timing mark.
7. Make sure that the distributor has been tightened. Remove the jumper wire from the timing terminal.
8. Remove jumper wire between the timing lead (PUR/WHT wire) and ground (-).
IMPORTANT: Be sure to disconnect the jumper wire from between the ignition system timing lead and ground (-) before attempting to resume normal operations. If the jumper wire is left in place, the ignition module will operate in the “Base Timing Mode”. This means that the additional timing advance features would not function.
9. Stop engine and remove timing light.
tank1949
Non vortec and non-roller cam. Boat bought used so I don't know all details. Blocks have manual fuel pumps.
tank1949
Do I still disconnect knock sensor connection????
