Base timing
voodoo
I assume poor base timing will contribute to poor idling and stalling, can you time this by ear/feel and not a gun?<br />Is it that critical at idle?<br />Thanks
rodbolt
Re: Base timing
yes no<br /> get a timing light. set engine timing according to specs. improper ign timing can cause a major meltdown.<br />it also needs to be double checked at WOT.<br /> but do it with a load or a test wheel.<br /> good luck and keep posting
voodoo
Re: Base timing
It runs a1 from just off idle to wot 5500rpm. Plugs look excellent, I even pulled the head at 5 hours for a quick peek.<br />Rebuilt powerhead, timing is set at wot (by the rebuilder I assume) however I re and re'd carbs, linkage and cables and am not sure about the syncro. Is there a preference to sync all 3 carbs at the same vacuum or is it by sight?<br />I really don't want to tie it to the dock and idle.<br />I have always timed my larger motors by ear but if that's a bad idea......
Hooty
Re: Base timing
I think you're probably talking about the pickup timing. It's been my experience if you do the carburetor link & sync and then full advance timing, the pickup timing will take care of itself. Don't adjust idle speed with the timing adjustment. Do that with the carburator idle adjustment.<br /><br />c/6<br />Hooty
ob
Re: Base timing
voodoo,Post a model number for the engine in question.It will help to narrow down the specifics of the info we can give as to fine tuning this puppy.
voodoo
Re: Base timing
CE65WMLZ.... we (here) haven't quite figured it out but believe it's a 1990 Canadian Evinrude (although it's painted charcoal with Johnson badges) 65HP commercial
