larryhorne
Thread starter- Joined
- Sep 29, 2008
- 14
I recently bought a used 1989 (I think) 20HP Evinrude Model E20CRLCEM Serial #R08154848 long shaft and I'd like some basic information if you can.
I plan using it on a 12ft Carolina Skiff that I am restoring.
I was told when I bought the motor that it had been upgraded to a 25HP, I assume though intake change.
The motor is running fine. It has a few issues. The kill switch does not work so I will replace it and the prop is nicked so that too will be replaced. I plan to replace the water pump, lower unit oil and spark plugs.
What can you guys tell me about this model and year. What should I look for to ensure reliability?
Do you know RPM at WOT? Oil Ratio?
Many Thanks
Lar
Many Thanks
Lar
