Basic specs. Help! Mercruiser 260
Rail Meat
What oil weight and filter for the Mercruiser 260 alpha one? Air filter?
Fordiesel69
Re: Basic specs. Help! Mercruiser 260
SAE30 with a mercuiser filter. Once you find the quicksiliver number, some napa filters may be a available. AVOID fram oil filters.
180shabah
There is no air filter - the flame arrestor is all metal and washable.
dgopetactical
napa 1061 or wix 51061, fram ph 30 oil filter.
oil weight
ambient temp below 32 deg use sae 20w oil
ambient temp 32-50 deg use sae 30w oil
ambient temp above 50 (most common) use 40w oil
if straight oil is not available use 20w-40
this is what is "Recomended" from mercruiser for that engine/ year..this info was not intended to start another "oil" thread. If you disagree contact mercruiser....LOL:D
Denny
