Basic Sterndrive Configuration Questions
HT32BSX115
If you put closed cooling on it, you could even do aluminum heads and intake manifold too.
wouldn't be cheap though.......
however with the stock cast iron heads at 80# a piece or the Merlin's I have at 85, a 30# head would be nice, especially when building the motor and lifting the dang things.
HX adds weight back (adding about 70# to the motor)
HX is $600 alone if you have connections. add to that the required brackets, plumbing, etc and your into the $1200 range
I can tell you from first hand experience, what ever you do, get a complete motor with all the brackets, accessories, etc.
