crazy charlie
- Joined
- May 22, 2003
- 5,725
I cant seem to find these guys on line.I have been using them for years.Any one have any info??I was about to oredr a new set of mANI AND RISERS.Charlie
Fishermark said:They're fine until you need to return something. I ordered a transom seal (the big foam rubber o ring) from them when I replaced the Alpha one transom assembly on my boat. It was a bad part I received. It appeared that the glued end had come apart and instead of a big circle, it was like a piece of foam rubber rope. No big deal, I called them and explained the problem and they said to send it back. I returned it to them. They sent me another part. Same thing. I called them again and they cussed me out and told me to return the part and never order from them again. I kid you not!
Don said:Fishermark said:They're fine until you need to return something. I ordered a transom seal (the big foam rubber o ring) from them when I replaced the Alpha one transom assembly on my boat. It was a bad part I received. It appeared that the glued end had come apart and instead of a big circle, it was like a piece of foam rubber rope. No big deal, I called them and explained the problem and they said to send it back. I returned it to them. They sent me another part. Same thing. I called them again and they cussed me out and told me to return the part and never order from them again. I kid you not!
Those seals aren't in a ring, and they are too long. You glue them into the groove as you go, then cut to length and put glue on the ends. Merc, Volvo, OMC, all the same.
Fishermark said:It is "ebasicpower" - and while they have good prices, they have THE WORST customer service of any place I have ever used. Period.
Fishermark said:They're fine until you need to return something. I ordered a transom seal (the big foam rubber o ring) from them when I replaced the Alpha one transom assembly on my boat. It was a bad part I received. It appeared that the glued end had come apart and instead of a big circle, it was like a piece of foam rubber rope. No big deal, I called them and explained the problem and they said to send it back. I returned it to them. They sent me another part. Same thing. I called them again and they cussed me out and told me to return the part and never order from them again. I kid you not! I hadn't been rude on the phone or anything and was shocked at the reaction I got from them.
About a year later my dad needed some parts and so I reluctantly ordered from them again. The parts never came in the mail, so I called to check. They actually have me on some sort of "black list" and won't even sell anything to me. They didn't bother to mention anything - even by email when I ordered, just didn't send the parts. All this because I returned defective parts twice.
Needless to say they will never get my business again.
Not that they would take it either apparently!![]()
