Novax
Thread starter- Joined
- Aug 19, 2012
- 48
I have a 1986 Astroglass 17' 5" bass boat that has a soft spot in the floor close to the front deck. I want to extend the deck back to the console but not sure if I should fix the soft spot or just build over it. If I build over it I was planning on laying some aluminum down for the flooring of the new deck and add a new livewell and maybe another place for storage. My first question is should I fix the soft spot or just build over it using the aluminum as the cover for it? The reason I'm extending the deck is because there is only like a foot of space between the seat post and the edge of the deck plus the front livewell is very small (Probably used as a bait tank?) and I want to add a bigger one. My next question is, what would you suggest to build this extension with? I'd like to keep it as cheap (but still well built) as possible so aluminum is not an option... 1x1, 2x2, 2x4? Thickness of the decking?
Just some thoughts...I've never built anything for a boat so not sure if I should even try it.
