Batteries not charging?
waltzal
I have a 2002 Carver Mariner. When plugged into shore power the engine kick right over. However, after cruising awhile and stopping engines, he engines won't turn over. It seems the batteries either don't have enough juice or something else is wrog. If I start the generator, I can kick over the engines. Any ideas what is wrong? :confused:
Silvertip
Re: Batteries not charging?
With the engine off, no shore power and no generator, measure the voltage at the battery. Start the engine and then turn off the generator and shore power. Measure the battery voltage at about 1500 rpm. If it is less than 13.5 - 14.5 volts the charging system is not working. Your boat should also have a voltmeter or ampmeter on the console. What does it indicate? An amp meter reads -60 - 0 - +60 or -30 - 0 - +30. If the gauge reads in in minus range the charging system is not working. If you have a voltmeter the gauge reads about 8 - 18 volts typical. If the gauge indicates less than 13.5 volts with the engine running the charging system is not working. Since the engine kicks over on shore power or generator, that says the cabling is probably ok. Battery condition is question able here and can be load tested at any auto parts store. I suspect however that the charging system is not working or that there is a transfer switch somewhere in the system that is not functioning properly.
joed
A running engine should not drain the battery. Even if you are using a radio and fishfinder. The battery should have enough power to restart the engine. It takes quite a while to drain down a battery. I had a engine that wasn't charging and I would run two radios, downriggers, fish finder and still be able to restart the engine.
Sounds like the battery is bad or some of the connections have corroded. Have you tried putting the battery on a charger over night?
waltzal
Thanks for the help. It appears the batteries were bad. The boat is a 2003 with original batteries.
