battery cable for 112 johnson
66 joe
After hours of trouble shooting, finally decided to clean my battery contacts only to discover neg cable from batteries was solid as a rock!
also feels like it breaking up inside. I need info on where to get replacement and what caused this.
Thanks, Joe:confused:
billy4hp
Re: battery cable for 112 johnson
Well what caused it is plain and simple corrosion which wicks it way up the cable / wire. If it occurred at the battery end then it's likely the battery post seal had failed and battery acid wicked up into the cable causes the corrosion process to occur even quicker...
As far as replacing it, and if it's an eyelet to eyelet cable (like most marine battery cables I have seen myself)... I prefer to make my own from welding cable and crimpable ends... You can get most everything you need from a well stocked automotive electrical store, heck even some NAPA's carry everything you will need...
Good luck...
66 joe
I cant find replacement cable. Thanks, Im gonna try welding cable.
I know it has to be real flexible for outboard
JB
If you don't want to replace it every few years get marine grade, tinned wire. It will be flexible and resist corrosion 10 times as long as welding cable.
66 joe
I cant find stock replacement. anybody care to chime in on where to buy and maybe part #'s?
