tredragon
Thread starter- Joined
- Jul 2, 2008
- 122
My battery ran dead a few times last weekend and needed a jump. Needless to say, having the shift shaft stuck in forward didn't help the poor battery start the boat, which contributed to the problem. I had to jump it today off the car and it fired up within 15 seconds or so. It's not running currently (I cut it off after I made sure the gears were working properly with the muffs on)... but is still hooked up (the battery anyways) to the running car via the jumpers.
How long (since I don't have a battery charger... and yes it's next on my list) should I leave it hooked to the car to have enough charge to get an initial start this weekend when we go to the lake again? And after that, running it at idle for 20 minutes, then full out for 10 minutes after getting out of the creek and into the lake... will it be charged enough to start again? Maybe a borderline question but...
Also, I bought one of those Black and Decker jump start packs... basically a battery you can plug in and then just keep in the boat/car if you need a jump... it doesn't seem to be working and I'm wondering if I DO get a charger... should I just get a smaller "piggy back" battery to keep on the boat for those "just in case" scenarios??
Thanks in advance for your help.
