battery charger question....
Lou C
Question, I have an older Schumacher "smart" charger that I have had, about 10 years. Today I was using it to charge one of batteries on the boat, the other battery I was charging with a newer NOCO 10 amp charger. Just out of curiosity I checked the charging voltage of both batteries, the one on the Schumacher was between 16-17 volts (and was reading 12.5 V before I hooked up the charger) whereas the one on the NOCO charger was reading between 13.6-14 Volts. Question, is the old Schumacher charging at too high a level for safety? It does have a voltage read out when it is charging but it never goes as high as what I measured.
tpenfield
16 volts is a bit high. You don't want to go much over 14 volts to charge.
Lou C
That's what I thought, I'm not going to use that one anymore. The NOCO seems to charge at a rate safer for the batteries.
mike_i
Just to confirm, did you use a digital voltmeter to measure the voltage and not depend on a built in meter on the chargers?
