Saw this advertised on eBay and wonder if it is safe to use and wothwhile or if it is a safety risk. It has a pair of red and black battery cables on one end connected to a 12V charging module and an AC transformer on the other end.
The link is here if you want to see the picture: http://cgi.ebay.com/ebaymotors/83-8...tegoryZ33578QQihZ020QQitemZ300078137034QQrdZ1
Any thoughts? I have a 1990 Ciera 2651 Sunbridge.
Thanks.
THE PROBLEM: You try to start your boat after it's been
sitting for a few weeks or months, and your
battery is completely dead.
THE SOLUTION: The Battery Butler® Storage Charger!
The Battery Butler® Battery Storage
Chargers are specifically designed for the maintenance of batteries that are stored or only
used periodically. These chargers will prevent the normal self-discharge of your battery,
while extending the life of rechargeable 12 volt batteries rated from 5 to 125 amp-hours,
by providing a minimum current, regulated output. Other types of chargers provide
a strong, rapid charge that tend to boil out liquids and decay electrodes.
With the Battery Butler® charger, once your battery has been fully charged,
it will automatically shut-off; then resume charging as your battery level drops.
Works on ALL wet cell, gel-cell or the new OPTIMA batteries.
Works on ALL years, ALL make & model car, truck, motorcycle or boat batteries.
The Battery Butler® Battery Storage Chargers are specifically designed for long term use.
You can safely leave it connected to your battery for days, weeks,
months, even years!
Did you know that every week your battery will lose 4% of its charge
just by sitting (with no load)?
Thanks.
months, even years!
