Battery Charger
maldoro
I am new to trolling motor batteries. I have the following charger. Would this be sufficient to charge my deep cycle batteries or should I invest in something different
75 Amp Engine Start - 25 Amp / 10 Amp / 2 Amp Continuous Charge Rates - Smart Battery Charger?
Black and Decker Model # VEC1095ABD
3 stage, automatic, high-frequency charging technology
Microprocessor control digital diagnostics & fault codes
Spark-resistant, reverse hook-up & overcharge protection
Patented vehicle alternator check & engine start feature
Automatic float mode monitoring
All 12 volt lead-acid battery types
Ideal for use with Cars, Boats, Lawn Mowers, RVs, ATVs
Silvertip
Re: Battery Charger
It's fine. Use the charge rate that is 20% (or thereabouts) of the AH (amp/hour) rating of the battery. If you have a 70 AH battery, it should be charged at a rate no higher than 14 amps.
