battery charger
pocon1
I have a 4.5 evinrude mod: CSS E5R battery charger does the charger delivers 6 amp / Hr?.
You must have a charge controller or voltage?
Thanks for the reply
Tengo un motor fuera de borda evinrude 4.5 con cargador de bateria; quisiera saber si carga 6 amp/hora y si necesita regulador de carga. Tambien quiero saber por tanto cuantos volts entrega por hora
Gracias
pocon1
Re: Larson Boat Covers
Tengo un mod 4,5 evinrude: CSS E5R con cargador de bater?a. El cargador suministra 6 amperios / hora?.
Debe tener un controlador de carga o tensi?n? y quisiera saber cuantos volts entrega
Gracias por la respuesta
pocon1
battery charger
would like to know amperage motor delivers 4.5 hp evinrude for charging battery and charge controller do you need?
tx1961whaler
Re: battery charger
4 posts on the same thing. I can't really understand any of them.......
Are you wondering how much current the charging circuit puts out for a 4.5hp Evinrude?
I think you have a 1980, 4.5hp model E5RCSS......if so that does not appear to have a charging circuit.
Re: battery charger
your english is hard to understand i think you are asking if your motor generates 6amp/hr and something about a regulator but im unsure as this is your 4th attempt please list your native language so we can see if someone can translate for us. if english is your first language then im sry and thanks for the reply
F_R
Re: battery charger
Unless you have one with the AC lighting coils. In that case, it will charge a battery if you install a rectifier kit. How about posting your model number so we know what we are dealing with?
pocon1
Re: battery charger
si ,pero quisiera saber que voltaje entrega .
Evinrude 4.5hp. a?o 1980, modelo E5RLCSS
Gracias
Bob_VT
Re: battery charger
Please respond in English. You may ad another language but responses should be in English
Your battery charger is an electrical question and ALL of the same posts including this one will be moved there.
tx1961whaler
Re: battery charger
Si hay una salida de tensi?n, que es corriente alterna (CA) para el funcionamiento de las l?mparas peque?as. Se puede rectificar con diodos para corriente directa (DC) para cargar una bater?a de 12 voltios. Se puso 1 a 2 amperios.
La culpa de Google para la traducci?n est? mal!
pocon1
Re: battery charger
I would like to know what voltage delivery . 4.5HP Evinrude year 1980 model E5RLCSS Thanks
ray85
Re: battery charger
Hi
As much as i know it should be 13 - 14 VAC in case you don't have any charge rectifier. and the current delivery would be 6 Amp/hour. If you want charge battery from it you need a charge controller . Selection of charge controller depends upon Battery ratings you are using ! Hope that would be the answer of your question.
turn-key PCB assembly
