Battery Drain Question
JohnnySCV
Re: Battery Drain Question
Got the battery replaced and went out on the lake. Spent a few hours on the water without a lot of wind at all, mostly just used the trolling motor for slowly work the shore. Came home and tested the batteries. 12.8 on one and 12.78 on the other. Used two volt meters just to make sure and readings were identical.
Looks like all is woking as it should be. Thank you again guys...
