battery not charging
alwill
I have a merc 1990 40 h.p. Been sitting up for 4 years. Bought a new battery, but it will not charge. Could this be the rectifier? Is this a small 2 inch square box with three wires beside the motor? I need to stop giving the shop $200 or more every visit.
brother chris
Re: battery not charging
Well, I would opt for the rectifier. I had the same problem. I changed the rectifier and all was good. <br />Happy boating... :D
superman
Sounds like your describing the rectifier. The bridge rectifer is usually the problem. Besides its cheaper and easier to change then the stator and fails more. I'd change it first. It you have a ohmmeter it is easy to check the stator and the rectifier.
Hooty
Gotta manual?<br /><br />c/6<br /><br />Hooty
