Battery not charging
bigmoose123
I got my boat in the water and ran good....for a while. it started missing and lost power. got a toe back and got home and found out the battery isnt charging.....what do i need to check befor buying parts to fix. the motor is a 1971 evinrude 60 triunph... any suggestions
Barnacle_Bill
Re: Battery not charging
Test your rectifier. They are usually the culprit especially if you ever caused a spark somewhere or hooked up your battery backwards even for a second.
R.Johnson
What condition is your wiring harness in? Not uncommon for the insulation on the harness to be in crumbs on that engine.
bigmoose123
my wiring looks good. how can i check to see if rectifier is bad
tashasdaddy
have your battery load tested at the auto parts store (free).
