bruceb58
Honorary Supreme Mariner
- Joined
- Mar 5, 2006
- 30,824
Re: Battery on/off switch
If your switch is 1 foot away from the battery or 3 ft away, you won't have "leaking" voltage.
First of all, the definition of direction of current and the direction of electrons are two different things and it doesn't matter whether you interrupt the negative or positive side. Since the convention with negative ground systems is to put the switch on the positive side, that is where you should put it. Every other switch on the boat switches on the positive side. Why all of a sudden is it best to put it on the negative side? And yes...I am a EE.Rule #1. ALWAYS follow the manufacturers recommendations on installing any accessory, regardless of what you may read elsewhere.I got in a huge argument with a guy who claimed to be an electrical engineer over this.
Now, when I installed my battery cutoff switch on my travel trailer, I put it in the negative (-) side. Current leaves the battery on that side and returns on the positive (+) side. The closer you can get the switch to the (-) side, the fewer chances you'll have of a short or other 'leaking' voltage.
When in doubt, always referr to rule #1!
