I bought a boat, it has two batteries, they are connected to a battery switch, (PERKO 8501DP), I was just playing with the boat so I can get used to where eveything is an works. If I put the switch in 1 or both batteries everything works if I switch to battey 2 nothing works, so I traced the cables and battery 2 the ground wire was not connected, well I went to connect the wire to the switch (by this time switch is off) and I got sparks and it got reallyyyyyyyyy hot, so I know there is something going on but I cant figured it out. I think when I connected the battery on switch 2 it fried that side because I connected battery one and everything works fine. the positive and negative wires from battery 2 got real hot so my question is do I just replace the wires just in case they are making contact somewhere that I dont know about, replace the battery, I know Im going to have to get another switch or replace everything and start fresh.
Boat is a 2003 Kencraft Challenger 206 center console (now they are called Sea Kings) yamaha 200 HDPI.
Thanks in advance
Armando
Thanks in advance
Armando
