lakeerieboater26
- Joined
- Jun 11, 2009
- 74
whats the best way to hook up 2 batteries ?
Some terminology corrections here. The batteries do not go to the switch "outlet". The only outlet on the switch is the COM (common) terminal and do not confuse that terminal with Ground (as in common ground) because they are not the same. The batteries are connected to the BAT 1 and BAT 2 terminals. Where you have the switch set determines whether BAT 1, BAT 2 or BOTH feed the COM terminal. Here is a diagram. All of the accessories except an automatic bilge pump would typically get connected to the COM terminal as well.
If you are talking about a 24 volt system, then they are connected like this! You can feed 12 volt accessories from this system if you wish. Otherwise eliminate those wires.
correct, you could even install a second alternator if space allows.
Adding a second alternator is NOT an option IF the intent is to parallel the two systems. You then have voltage regulators fighting for control of the system. If you want one alternator for the house side of the system and another for the starting system then fine but in this application "way over the top". The engine alternator on an I/O will be in the 50 amp minimum range and will provide a fair boost to the troller battery and as such can prolong on the water tiime. You can also use a VSR (voltage sensitive relay) in place of the switch. It charges the starting battery first then switches to the house/troller battery. No switching necessary. But the switch is far more versatile. Without going into a long discussion on how to use the switch, it is as simple as this: Whatever switch you have selected is what powers everything and it also determines which battery is being charged. With a switch you DO NOT connect accessories to the battery. You connect them to the COM terminal on the switch. When you are stopped and want to run accessories, switch to BAT 2 (house or troller). Simple as that. When you want to go again, switch to BAT 1 starting because it is the battery you are trying to protect. Folks need to think about WHY they NEED a switch rather than just seeing someone else with one and thinking they need one also.
If you want to charge both batteries while the engine is running, and use your deepcycle (house battery) for the stereo and lights and any other accessories, and your starting battery for starting your engine and running it. Without turning the switch from one battery to the next all the time, get a charge relay and a dual circuit battery switch.
Just turn the swich on, it does everything else by itself.
http://bluesea.com/category/2/productline/overview/329
http://bluesea.com/files/images/products/7650.jpg
