Battery size for Penta aq271
Brian WV
Recently acquired a sunrunner 235 weekender and it needs batteries. I referenced the engine manual and didn't see any guidelines as to what size to get. Would something along the lines of a 575 cold cranking amps be sufficient? Any help would be appreciated as I am tryin to fire it up this weekend. Oh the motor is rated for 270 hp. Thanks
Re: Battery size for Penta aq271
Ayuh,... Welcome Aboard,....
I'd consider that the absolute Minimum...
Brian WV
Thank you for the response
I certainly do not want the minimum. Any suggestion on a comfortable cca range?
Ayuh,.... Anything Higher will do....
Or,..
You can run multiple batteries like many of Us do, with a battery switch...
Don S
Volvo states a minimum of 650 CCA on todays V8 engines.
