Re: Battery Switches & Setups Demistified
There is a simple answere.
Wire your batteries to the battery switch with on battery (or bank of batteries) to the post marked 1. Wire your second battery (or bank) to post marked number 2 on the switch.
Put all of your loads, engine, house, stereos, radars, sirens, rocket launchers, depth finders, fish sounders and everything else on the post marked COM.
Wired this way, when you turn the switch to number 1, everything runs off 1. When you turn the switch to 2, everything runs off 2.
When you select BOTH everything runs off both and when the engine is running it charges both.
The trick is to remember to switch the switch. As long as you stay on 1 or 2 you will never run the batts dead. Forget, and leave it on BOTH, and you kill both.
enjoy
drewp
