Bayliner ,can i fish on bay?
GatorMike
Ensign
Re: Bayliner ,can i fish on bay?
Why would anybody be afraid to take a 19 footer out on a bay? I take my 19' Wellcraft to the Bahamas, just gotta watch the weather and make sure you have good equiptment on board. BTW we do the Bahama crossing with a buddy boat. Sometimes it helps to have another boat along until you get comfortable.
ebry710
Ensign
Sometimes it isn't the length of the boat, but the boat design. I think this is one of those times.
BWR1953
Exactly. I used to take this 17 footer out on the Chesapeake without worries. LOL :D
markfisher
this reply is for all users.
hello, i need your advice, the seller of this boat is picki, he does not want take the boat to professional to take a look, he says everything is ok whis boat , i dont know the reason ,he does not care much about it ,he is busy person,its 2003 bayliner 195br, in perfect condition, seller says i can hook the hose water and run the motor in garage , and i think i can check the oil, could you suggest something else to look for? to check for? this is my first boat i dont know much about it, asking price is 7000
xxturbowesxx
Its too much money and also there are to many boats out there to be nitpicking at one.. just walk away.. Buying a boat should take you at least a few weeks.. once you find a boat you think you must have then go look at 5 more and see if you feel the same way.. 7,000 will buy you a lot of boat.. also you should consider broadening your range to look for one as well.
i found these in a few min,im not saying buy one of these im just showing you that there are other boats out there..
http://richmond.craigslist.org/boa/1150944686.html
http://richmond.craigslist.org/boa/1150557684.html
http://richmond.craigslist.org/boa/1141594658.html
http://richmond.craigslist.org/boa/1127480771.html
http://richmond.craigslist.org/boa/1124351762.html
markfisher
am looking for long time,fishing boat , 19-2001 is more expensive than bayliner 19' 2003
markfisher
i mean years 1986-2001, am talking about center console, wife does not like that kind boat, but that understanble...
markfisher
guys i forgot to tell , i got nissan pathfinder 2008, 4.0L 6cyl, i hope its good enough to tow 18-20' long boat 1 axle trailer?
Sharkfighter
If you offered a deposit while you took it to a boat mechanic and he refused I would not get boat. Also a surveyor should go to the boat and check it out for you. Again if owner refuses to allow it then he can keep his boat in my opinion.
This is really a buyers market the way economy is and if you put a deposit down unless he has boat stored far from water why would he not want to do a sea test?
You can certainly start boat with hose in garage, check the engine tilt up and down and see if it moves with steering but sea tests are the norm.
Rob
rrhodes
If the owner does not want to allow a Marine inspection run away. He is hiding something.
ckone0814
if you're in Harrisburg you're near me, I'm in Berks County.
i just went through it all and ended up with a dual console boat, part inshore fishing boat and part fun. like you, my wife wasn't warm to the idea of a center console but don't put CCs aside just yet. there are some that are pretty comfy with pads and all so i'd continue to look at them. if the bay will be your most frequent choice of water get something with good deadrise and weight. the last thing you want to do is get a boat that you can't use unless the conditions are perfect. one problem though, towing a boat like that will probably take something bigger than an older Pathfinder.
do your research and keep looking - buying a boat isn't an impulse purchase. don't buy anything a seller isn't willing to seatrial or allow survey. there are tons of boats out there and prices are very negotiable. if I had a $7k budget I'd be looking up to $9k at least. don't be afraid to drive a couple of states away either - I went to CT for mine.
post any question you have right here. it's amazing how helpful people here are and how much knowledge they have. they'll also set you straight when/if you need it! good luck.
David Greer
You can crusie in a fishing boat but you can't fish in a cruising boat. All the living room furniture (cushions, carpet, tunes) just deteriorate esp. in salt. Your wifwe will be happier in a safe, stable dry boat and a seat cushion under her butt than a smelly swamping cruising boat.
My prejudices are obvious. But in my spare time I'm more of a waterman than a golfer.
markfisher
Good day gentlemen
Is this good boat?
2001 Bayliner Trophy 1903cc
A 19ft center console with a 2001 Mercury 125 saltwater series motor and escort trailer. Lowrance X71 fish finder and Lowrance globalmap gps, vhf radio, livewell, fishbox, cooler with seat cushion, rod holders, bimini top and full cover. This boat is ready to go fishing. Asking $10.000
ckone0814
There you go! you're getting warmer.
I'll let others comment on the specifics but I like where you're heading....
David Greer
agreed.
change the water pump if it's more than a couple years old and run in salt water.
markfisher
Guys i need your help, i got list of boat but i can't decide which one to go with here is list;
1997 18' Aquasport Center Console ,1998 90hp Evinrude w/ trailer - $4000
1999 21 Ft. Center Console with 200 hp Yamaha Salt Water Series with trailer$8999
Boat Sunbird 3.0 1993 19' 4cyl 140 HP with a trailer - $3500
2000 Trophy 19' center console - 125 Merc 2 stroke with oil injection$8350
2001,20' Center Console, Palm Beach, Model 205 -with a 150 hp Mercury Saltwater Edition engine $7500.
1995 MAKO 171 CC -1995 Mercury 125hp outboard and a 1995 trailer
$5600
1995 Welcraft Excel clean Must Go -19' cuddy cabin 4.3l mercruser i/o $6500
20' Seaswirl Striper Walkaround -1995 Seaswirl with 115 evinrude $7300
99 BAYLINER CAPRI 18.2LS -120 HP MERCURY $5995
2002 seafox,115 mercury 18-19f,$7000
1990,18' sport craft cc,85hp yamaha, $4500
2001 18ft maxum, 4cyl i/o, $5500
thanks all
ckone0814
just my opinion here so don't be offended...
way too much data. you aren't going to get too much help - people aren't going to pick the boat for you.
my advice is to do legwork on your own and get your list down to a few. go look at them, run them, research and read, then come back with details and specific questions.
dingbat
thanks all
Narrowed down a bit from my perspective.
xxturbowesxx
My vote goes to 2001,20' Center Console, Palm Beach, Model 205 -with a 150 hp Mercury Saltwater Edition engine $7500... Assuming the boat is in appropriate condition.. If you were not interested in a ski boat or anything then i would go with the 18' with the 90hp..
