bayliner capri cuddy Trim tabs
harbatinu
Hi,
I have a bayliner capri cuddy and i,ve bought trim tabs for it but i don't know how to mount them. Does anyone tell me how to mount them please.
Thank you
Ayuh,.... Welcome Aboard,... Trim tabs mount to the transom, it's tough to tell ya where to put 'em, lookin' at the side of the boat,....
Basically, mount 'em on the transom, as far outboard as possible,....
Tabman
iboats.com Partner
What type of Trim Tabs did you buy? Are they the self adjusting type, or remotely controlled ones? Did they come with instructions?
Bondo is on target, here is a drawing that will apply to just about any type of Trim Tabs:
harbatinu
They are self adjusting type. Yes they have instructions. Then problem is that the back of the bayliner is curved and when i measure 3"- 4" from chine the bracket does not fit and the problem where to mount the bracket and the actuator.
Tabman
iboats.com Partner
Do you have closer photos of the transom from right behind the boat and from the side?
harbatinu
No Title
These are the smart tabs I've bought
Tabman
iboats.com Partner
Can you position the Tabs there (on the red line) and position the actuators up on the blue part of the transom?
harbatinu
No Title
How much from chine to bracket plate please
Tabman
iboats.com Partner
It doesn't matter too much, as long as the tabs are somewhere on my original red line, you will be OK. The mounting plates should not be on your arrow. See my first drawing.
harbatinu
No Title
Thank you. Are they good like this before I mount them and do the holes please.
Tabman
iboats.com Partner
As long as there is no binding as it moves through it's range of motion you should be OK.
