Bayliner Deck Is Shot - Now What?
Jonnyp8689
Hi guys I'm new to the boating world. I bought an 1985 bayliner force 85 recently and found out the floor is shot and is rotted out. I just wanna know how to replace the floor myself and a step by step process on how to do it. It's a 15ft. If anyone can help me please contact me
64osby
Step one is to figure out what else is rotten. Inspect the transom and the stringers. My bet would be they are rotted out also.
further
Lots of good info on this forum. Do a search and look through the stickies at the top of the forum page - Pretty much everything and anything you'll need to know to restore your boat if that's what you decide to do. Lots of amazingly helpful people on here that I'm sure will chime in also. 1980's Bayliner construction was not very good and if your sole is soft and rotten, then likely the stringers and transom are too and you'll be in for a full restoration. Unfortunately very common with boats left out in the elements uncovered. I went through it myself with a maxum which is essentially the same as a bayliner in construction.
First thing is to start taking everything apart and out. Drill some holes into the stringers and transom and inspect the shavings. If they're dark and wet looking, you'll need to replace them. These components are the structure of your boat and need to be solid to be safe for use.
Good luck
tpenfield
Step by step instructions would be difficult to describe, but it would be best to read through the threads here on the restoration forum and you will get the general idea. Usually the floor rots last, so it is a matter of discovering and fixing all the things that have rotted out before the floor.
