Bayliner engine cover, help!!
briangcc
Given the age of the boat, your best bet is going to be your local upholstery shop. **This assumes that your boat is the one in the bottom photo and requires the padded top to the existing cover.
Riverside1600
Yes that is my boat? Thank you
southkogs
If you just need the vinyl, then as Brian says above: upholstery shop.
If you need the entire doghouse, then you're probably going to have to go one of a couple routes: you can look on ebay and see if anyone has one up for sale. You'll likely then have to replace vinyl. The other option is to make one out of wood. It won't be exact to what you have, but you can make something functional and nice.
Welcome aboard.
Riverside1600
Welcome aboard.
Thank you, matching the interior will be pretty hard.
southkogs
Exact match will be tough. But there are a lot of similar colors in use still. you can probably get pretty close.
