bayliner explosion you wont believe this!
carolynrose
Re: bayliner explosion you wont believe this!
Rarely do connecting rods, wrist pins, pistons break on their own. More than likely the bearing gave out or the rod bolt broke. Most manufacturers do not install high performnce hardware. When an engine over-revs the rod bolts stretch and break or the bearing walks over itself. Sometime just plain old fatique will cause the bolt to stretch and break. Most engine failures are caused by one of three things: Lack of lubrication, hardware(nuts&bolts) or timing failures (belts or chains). Hint: If the motor is in good working order a small investement in these three will insure extra life to the motor.
tds1774
I now have a pile of parts, and a big project. the good news is that the engine swap appears to be fairly simple. I wonder if it would be easier to pull the drive and attach it to the engine outside the boat, or just drop the engine in. I should probably check the transom at this point. It feels solid, but who knows what the inside looks like. how do you replace a transom with out damaging the exterior finish? very carefully right! Im a firm believer in "if it aint broke dont fix it" but then again I dont want to have to tear this thing apart again. do it once and be done with it. I think I will pull my floor my floors back out and look everything over once more. I will take some pics and post them to get you guy's opinion. thanks for everything yall are great!
haulnazz15
A little JB weld and some duct tape will fix this right up.
tds1774
I use 500 mph duck tape, and water proof cardboard. I also have bent welding rods, bubble gum, and some bungie cords. MacGuyver's on his way over a were gonna make this thig into a submarine! hahahahahahahahahaha
bruceb58
Thats a B23 Volvo engine...not a Ford
Howard Sterndrive
I vote egg.
suspect you'll find that piston seized. Then the con rod pulled out and did the rest.
Won't know till you get the head off, but I suspect that piston will be welded into the cylinder.
just a guess tho'
