Arawak
Thread starter- Joined
- Aug 27, 2010
- 486
I've come to the conclusion that the foam in the stern of my 17' 1988 Bayliner is soaked and needs to be replaced. Even with a light 250lb motor (Chrysler 105HP) she sits quite low in the water at the stern, and when I sit on the gunwales at the stern water will start to come in through the scuppers. The kicker is that after a run the bilge drain will drip for a solid day.
So... I want to remove the cap to have a look, and replace the old foam. Of course, although everything feels solid who knows what else I'll find. Hoping to avoid *another* transom rebuild but if it's got any rot spots I'll probably do it. And it will be a good opportunity to mount a second bilge pump, a through-hull transducer, and some other goodies.
Does anyone have any advice on how to get the top off? Since it's a centre console, it's a lot more to remove than the runabout caps I've taken off in the past since the sole is attached. I'm thinking I'll need to build some sort of a structure over the boat and then maybe some pulley system to lift the cap. Probably I'll have to support it as well, not quite sure how I'll do this...
Any advice appreciated, especially from anyone familiar with these boats.
