bayliner wireing
tucki111
looking for a fuse panel layout ie what each fusel is for on an 88 bayliner ciera 460 king cobra
HT32BSX115
Howdy,
Welcome aboard!
You might have to go to Bayliner if that fuse panel is OEM. It's also possible that it's been changed more than once in 27 years...........
If that's the case, you'll likely need to trace out each item and identify them the 'hard" way one at a time.
That will require an OMC (or equivalent) service manual that will identify the engine harness wire colors. (assuming someone hasn't done any splicing)
You might do it with A Seloc/Clymer manual but you'll want an OEM manual for anything else you do to the engine and drive. I wouldn't trust anything but OEM for that. If you haven't ran the boat, you should change/refill the drive lubricant. DEFINITELY use the OEM manual procedure for refilling that drive! Do it wrong and you'll buying another drive (if you can find one........ask me how I know!!)
Cheers,
Rick
southkogs
Go to Bayliner's site. They have quite a few reference manuals online. I was able to find one for my Capri there.
jerryjerry05
Send Bayliner your hull #.
They should have something that will help.
The engine harness uses a standard color code.
Things like horns and accessories are coded too.
I know the lights are grey, white.
